Can you check on my company account (hogak.co.kr) to make sure i can receive emails from you?
Hello, Good day. I don't see any block for this email domain. Please try again on your side. Thanks
@Mohanraj Thangamuthu Why can`t I receive verification email from you?? Can you send a E-mail to jwhong@hogak.co.kr ??
I have sent a test email now, please check if you have received. Thanks
You will not receive the email. I have received the following bounce again.
553 Your E-Mail Address does not designate Permitted Sender Hosts(SPF)
Please check the configuration in your mail server. Thanks
Hello, Good day. I am noticing the following error for this email addres. "Your E-Mail Address does not designate Permitted Sender Hosts(SPF)"
Unfortunately we don't have any control. Please check the setting on your end. Hope following link helps you. https://powerdmarc.com/spf-softfail-domain-does-not-designate-ip-as-permitted-sender/
Shouldn't the answer in this link take care of that?
