A quick reference of links/ previous posts,; for Efficient ways of handling projects/issues
sureshksuresh95
This question is for the quick help of a Project Lead/Manager, who is new of project operations using 'Jira software'.  Are there any quick reference of links/posts, stating on - " efficient ways of handling the issues / and efficient usage of Jira as tool!! etc."
In other project management tools; project creation is pretty much similar for any type of project ! But in Jira, it is highly customized.
Right from the FIRST step-  ( In 'new' project creation); it expects you to know a lot more Jira internals (templates, issues, schemes etc.), which bothers some time!!
Thanks in adavnce.
John Funk
Hi @sureshksuresh95  - You really only create projects one of two ways. You create a new project from scratch and Jira creates the corresponding workflows, schemes, etc.
Or you create a project based on an existing project - this will inherit the workflow and other schemes associated with the base project.
sureshksuresh95
Yes ! I understood as user, I need not bother about workflow, scheme etc.
Let me put my question slightly different..
I look for- some quick reference / links immediately that help as first hand guide for all the  new bees like me (rather going elaborate Atlasian documentation).
Thanks again.
John Funk
sureshksuresh95
Thank you.
John Funk
If that answered your question, can you click on the Accept answer button above to close this one out? Thanks!
sureshksuresh95
partially I got the answer.  BTW, I close this.
Thanks.
