Greetings!
I'm pretty new to this whole Scriptrunner thing, so I'm looking for some help with a scripted field. I'm looking for a script, which would allow me to divide a variable value on a static one and show a result as a percentage.
I'm going to use two custom fields for a variable value and a result of this equation.
Something like this:
N (variable) / 40 = Z%
What do you mean that you will use two custom fields for a variable value? one value can be used for one field or there is something else?
Basically your script would look like this
def cs = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("customfieldname");
return issue.getCustomFieldValue(cs)/150
Morning!
Well, I'm talking about configuring two separate fields: a field for user's value and a field to show a result.
Right now, with your script (thanks for that!), it looks like this:
http://prntscr.com/i5sb9n
The result, I'm looking for:
http://prntscr.com/i5se8j
Then you need to create a scripted field with a script like this
return issue.getCustomFieldValue(cs)/40*100
