A vulnerable issue for Path Traversal,
willie March 8, 2023
Hi All
I have a vulnerable issue for Path Traversal, how can I fix this issue with on-premise environment (v7.6.13)
[JSDSERVER-6589] URL path traversal allows information disclosure - CVE-2019-15004 - Create and track feature requests for Atlassian products.
PS: Hopefully  you can give me any user-guideline, thanks.
Willie
Kai Becker
Hi @willie ,
Welcome to the community. Your Jira instance needs to be upgraded asap. This vulnerability is known for more than two years.
all information about it should be documented here: https://confluence.atlassian.com/adminjiraserver/jira-service-desk-security-advisory-2019-11-06-1047539905.html
Hi @Kai Becker
Thanks very much for your help, please do me a favor again, what will be happened  if  I add rules to JIRA system as following codes.
I can't update to latest version, because my Jira is on-premise(v7.6.13), in other words, I have to use this rules for a  vary long time,  Will the JIRA application be affected?
Please give me more messages about this issue, thanks again
<rule>
    <from>/servicedesk/.*\.jsp.*</from>
    <to type="temporary-redirect">/</to>
</rule>
Hi @Kai Becker
Sorry bother you again, if I want to add the rules into the urlrewriter.xml , how can I do with multiple "Rules"
For example: this is my JIRA urlrewriter.xml content, how to add a another rule
<urlrewrite>
<!-- Caching of static resources -->
<class-rule class="com.atlassian.jira.plugin.webresource.CachingResourceDownloadRewriteRule"/>
<!-- @since 5.0 [KickAss]-->
<rule>
  <from>^/issues(\?.*)?$</from>
  <to type="permanent-redirect">issues/$1</to>
</rule>
### Could I add this codes under the this position
<rule>
</rule>
</urlrewrite>
Thanks again ,
Willie
Kai Becker
Hi @willie ,
sorry for the late response. I'm not an sysadmin, so I can't  give you any tips/hints on url rewrite stuff. Sorry about that.
But I would highly recommend, that your Jira should not be accessible outside your company network. Jira 7.6.x reached End of Life on 16 November, 2019, so there might be a lot more vulnerabilities in your current setup.
willie March 14, 2023
Hi @Kai Becker
Sorry to bother you again, I've tried many times with production and staging server but unfortunately, it isn't working for me, please do me a favor, thanks again.
PS: Please check my test recording
Hi @Kai Becker
I've tried to disable the jira-dnd-attachment-plugin but it still show "Path Traversalissue, please help me. thanks.
bash /opt/jira/bin/start-jira.sh --disable-addons=com.atlassian.jira.plugins.jira-dnd-attachment-plugin
