A way to hide Confluence icon in Jira issues ?
Aline Veyradier
I'm looking for a way to hide this Confluence icon that recently appeared in Jira issues because we don't use this application and it's confusing for users.
Does anyone have any ideas? Thanks in advance
Best regards
Aline
6 votes
Manoj Gangwar
Hi @Aline Veyradier
If Jira is linked to a Confluence instance (even if you're not actively using it), the icon may appear. Disabling the application link could remove the icon
Steps:
Go to Jira Settings > Applications.
Select Application Links.
Find the Confluence link (if present) and either disable or delete the application link.
This should remove any integrations with Confluence, including the icon.
Aline Veyradier
Hello @Manoj Gangwar ,
Thanks for your help. I think I've found what you mean, but by a different way :
https://xxx.atlassian.net/jira/settings/products/confluence
Best regards
Aline
Like # people like this
