Add Comment on Transition using power script?
Sravani Battu September 24, 2021
I want whenever an issue is transitioned from one status to another, system should automatically add a comment like- updated by XXX.
I have not used power script till now.
Can you please help.
Fabian Lim
Hi @Sravani Battu
In the transition postfunction, select sil script and use the following function: https://confluence.cprime.io/plugins/servlet/mobile?contentId=6560411#content/view/6560411
Refer to the example
Regards
Sravani Battu September 27, 2021
Hi Fabian,
Thank you for your help.
