Add an "issue link" to an external web page in the JIRA issue create screen
David at David Simpson Apps
Is there a way to add a "Web Link" i.e. an Issue Link to an external system on the issue creation screen?
I can't see a good way of doing this.
Warren
September 12, 2017
There is - I added a couple the other day. You need to have system Admin rights to do this.
Add a Custom field, then on the Select a Field Type, click on Advanced (down the left side) and select Message Custom Field, as per below
Do you mean create a custom field and add the web link in that?
Or this will create an external link in the Issue Link section?
I'm after the latter.
Warren
September 12, 2017
As described above, you create a specific type of Custom Field and associate it with the Create screen. You can then put in any HTML / wiki markup as default text. When finished it will look something like this :
