Hi
I thought that I have asked this question before but I can'r find an answer in the forum.
The case is that I need to add some more fields on an issue, and I know how to do that, I can see the new fields on an issue, in my case Stakeholder and Size.
I looked at this guide, but it does not look like the way an issues a presented in my version of Jira, I can't find the label/dropdown named Column.
https://support.atlassian.com/jira-cloud-administration/docs/configure-the-default-issue-navigator/
Ihave added i screen shoot of my view of an issue list
Ok, but that is not what I want to do, I want to add columns in the list view and also remove some columns
Some columns are not relevant for some users
We want to add the following columns in the list view, they are already added on the issue card.
* Stakeholder
* Area
* Size (XS, S, M, L, XL, XXL)
Hi If you have admin access, you may able to configure the required columns for self / all jira users, by accessing the below
Where "My Defaults" shows the required columns for yourself, and "System" will configurable to all the jira users.
