Add commit in Jira Task bug mapping problem
stepan.sadko March 12, 2025
When you click + in the commit field, the Copy issue key window is displayed, where it is impossible to copy through the button as it is closed by the information window. I have to move the cursor away and point it again at the text itself and copy it with command+c.
Bug works at all screen resolutions. Screenshots attached
Is there anything that can be done about it? As I understand the window should be displayed without closing the required fields. Thanks!
Mohanraj Thangamuthu
March 12, 2025
Hello, Good day. It works fine for me, whether you are noticing this issue on a specific web browser ?
stepan.sadko March 14, 2025
Here you press the Create new brantch button - it works correctly. I meant button Commit +
Tried in chrome and safari browsers behave the same way.
Screenshot at Mar 14 17-47-41.pngScreenshot at Mar 14 17-47-01.pngScreenshot at Mar 14 17-46-39.png
