Add red asterisk for required fields on state transition
Monica Gupta July 24, 2025
I want red asterisk on required fields on state transition. I am not looking for Atlassian to provide a solution, did anyone found a workaround via a css, scriptrunner etc. to accomplish this?
Tinker Fadoua
@Tinker Fadoua  Where in the code it highlights the field in a different color?
Rajat Pratap Singh
July 24, 2025
I dont think Jira cloud allows altering the UI (like adding red asterix for required fields) like it did in datacenter.
To guide users, you can add “Required” in the field’s description as a workaround.
This does not meet the requirement to be implemented in state transition
Rajat Pratap Singh
July 24, 2025
Hi @Monica Gupta
How about adding a transition screen with the mandatory fields to the state transition.
These fields can then show as 'Required' if empty when performing the state transition.
Regards
Rajat
Like Monica Gupta likes this
Monica Gupta July 25, 2025
Problem is at each transition screen required fields are different, what is required in one transition screen might not be required in a previous screen
ENTERPRISE
