Add several links in Jira automation
Orly Dahan
I have a manual automation that creates 7 stories.
When I create the 3rd one, I need to link the previous 2 as "is blocked by".
I tried to use the following (used Create variable for the keys of the 2 issues), but for some reason, only the last one is linked.
What am I missing?
 {"update": {
"issuelinks": [
              "add": {
                  "type": {
                   "name": "Blocks"
               "inwardIssue": {
                "key": "{{FirstKey}}"
               "inwardIssue": {
              "key": "{{SeconKey}}"
Trudy Claspill
Hello @Orly Dahan
I have looked for answers and tried a few things myself, but not found a solution.
If I try to do this without Advanced Edit, and simply by putting the two issue key variables in thus:
...then I get this error in the rule Audit Log:
I am starting to wonder if adding an Issue Link is limited to one issue per Action.
Orly Dahan
Hi @Trudy Claspill
I think that you are right and that is why eventually I split it:
