Add weblink in issue to a comment in same issue
Marcel Vlems August 24, 2022
I have added a link to a SharePoint-file as a weblink in an issue. I want to use this link in a comment in the same issue but I cannot do that. Anyone knows if this is possible?
Mark Segall
Hi @Marcel Vlems - I'd need a bit more information on this, but you can add links to comments in markdown format:
[Test|https://www.example.com]
We currently use Jira Server and if I have added an image to an issue, you can show this image in a comment. See screenshot. I would like to do the same with a weblink but that's not possible.image.png
Mark Segall
Thanks for clarifying.  Correct, there is no way to link a weblink into a comment.  You would have to link to the same source as the weblink.
