Adding Sprints and Backlog to Project Settings in JIRA
Charlie February 8, 2018
I created a project in JIRA as a basic software project, I can't see Sprints or Backlog in the Project Settings on the left column menu. How do I add this?
Thank you.
Alexey Matveev
February 8, 2018
You should create a board. You can find more info here:
https://confluence.atlassian.com/agile/jira-agile-user-s-guide/creating-a-board
Hi Alexey,
That link points to a set up I don't have, looks like Agile has to be enabled in JIRA, I don't see that in the add-ons list at all. Is this an upgrade or an add-on?
Alexey Matveev
February 8, 2018
What version of Jira do you have? Is it Jira Software? How did you create a basic software project? There can be something wrong with the Jira Software functionality. Kindly have a look in the atlassian-jira.log for errors.
Charlie February 9, 2018
Hi Alexey,
It's JIRA Software version 7.5.1
When I go to create a project I see several options, the only ones we're interested in are Basic Software Projects, I do see the Scrum option above the Basic one, but I have not created any Scrum projects yet.
Here are some of the ERRORs I filtered out of the log file:
2018-02-09 14:14:21,671 HealthCheck:thread-8 ERROR      [c.a.t.j.healthcheck.support.EolSupportHealthCheck] An error occurred when performing the EOL check, see the exceptions for more info
2018-02-09 14:17:33,649 Caesium-1-4 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:22:33,650 Caesium-1-4 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:27:33,647 Caesium-1-4 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:32:33,647 Caesium-1-1 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:37:33,647 Caesium-1-4 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:42:33,651 Caesium-1-2 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:47:33,658 Caesium-1-3 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:52:33,647 Caesium-1-3 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 14:57:33,627 Caesium-1-1 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 15:02:33,664 Caesium-1-3 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 15:07:33,649 Caesium-1-2 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
2018-02-09 15:12:33,663 Caesium-1-2 ERROR ServiceRunner     [c.a.j.p.devstatus.provider.DefaultDevSummaryPollService] com.atlassian.applinks.internal.common.auth.oauth.OAuthMessageProblemException: OAuth authentication failed: consumer_key_unknown
Alexey Matveev
February 9, 2018
I can not see anything bad concerning your problem in the log. Could you go to coq wheel -> Applications -> Versions and Licenses. Kindly check if your license is ok.
Alexey Matveev
February 9, 2018
And also kndly make sure that your user is a jira software user. You can go to User Management, find your user and in the Applications column you should see Jira Software
Charlie February 13, 2018
Hi Alexey,
Thank you again for your replies. Under the Applications area I have:
JIRA Software 7.5.1
We have several users already on this system and they're all set up for JIRA Software.
The only thing I can say that may be a problem is that we have exceeded the license pool. We started with the basic 10 license package, but we're in the process of upgrading to 50 licenses as soon as procurement has completed.
Thank you.
