Hi all,
I just wanted to know whether we can add test cases to a test run through JIra Rest API .I was able to add sub tasks too but couldn't find a proper way to add test cases.
/Lahiru
Hi Lahiru,
This has been discussed here - https://community.atlassian.com/t5/Jira-questions/Test-Case-step-status-update-via-REST/qaq-p/729221
Please take a look.
Hope this helps.
Warm Regards,
Raja
Hi Lahiru
You must use the REST API something like below
For example for Xray Add-on: /rest/raven/1.0/import/execution
hope this helps!
Warm Regards,
Raja
Yes i'm using Rest API , But i wanted is the Base URL ?? Such as where to mention TestRun Key , and where to mention Test Case ket etc. Any way i'll try to find it .
/LahiruW
Hi All,
Isnt there a way to assign a test case to a test run using REST url like below other than xray ?
/rest/api/2/issue/createmeta
/LahiruW
