Honestly not really sure where to start here. Had a look at writing a custom listener but wasn't sure how to get context for the issue. The listener would need to rigger on CustomFieldUpdatedEvent events and add a comment to the issue that contained the assignee and the current user. The customfield is a single choice dropdown list and I only want the comment added when it is set to a specific value. Any help would be greatly appreciated! Thanks
Hi Charles,
Have you looked into solution like Automation for Jira ?
Florian
Thanks for a quick reply.
Looked into it yes, however, I already have a scriptrunner license and set up (with some other scripts) so I was looking for a way of achieving this with scriptrunner as well.
Hi Charles,
I've just found this script from Aidan Derossett on another Community post (https://community.atlassian.com/t5/Marketplace-Apps-Integrations/need-a-script-to-copy-a-custom-field-to-comments-with/qaq-p/606253.)
It might help.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.event.type.EventDispatchOption //Grab necessary components def projectManager = ComponentAccessor.projectManager def issueManager = ComponentAccessor.issueManager def cfm = ComponentAccessor.customFieldManager def commentManager = ComponentAccessor.commentManager //Get the project you wish to run this script on and retrieve all of the relevant issues def projectID = projectManager.getProjectByCurrentKey("Project Key").id def issueIDs = issueManager.getIssueIdsForProject(projectID) //Get logged in user that will act as the commenter def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser //Go through every issue ID and transfer the desired text custom field to a comment issueIDs.each{ def currentIssue = issueManager.getIssueObject(it) def currentCustomField = cfm.getCustomFieldObjectByName("Custom Field Name") def currentCFValue = currentIssue.getCustomFieldValue(currentCustomField) //Check for null custom field on the current issue if(currentCFValue) { //define the comment def valueToComment = "$currentCustomField.name: \n $currentCFValue" //Add the comment to the issue, delete the custom field value, and persist those changes to the DB commentManager.create(currentIssue, loggedInUser, valueToComment, true) currentIssue.setCustomFieldValue(currentCustomField, null) issueManager.updateIssue(loggedInUser, currentIssue, EventDispatchOption.ISSUE_UPDATED, false) } }
Florian
