I need to take values from a multiselect field, convert them to an assigned value, then add them to a text field in comma separated form. Is this possible?
I currently can take a single select field, convert it, then send to a text field.
Hi, so you are doing this with ScriptRunner, right? Is it ok to share the script you've got so far?
import groovy.transform.BaseScript
import com.atlassian.jira.ComponentAccessor
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.fields.config.FieldConfigImpl
@BaseScript FieldBehaviours fieldBehaviours
def optionsManager = ComponentAccessor.getOptionsManager()
// Get the Custom Field Manager
// Get a pointer to my select list custom fields
def selectList1 = getFieldByName("G4 - Systems")
def selectList2 = getFieldByName("StatusPage_ID_Text")
def textBox1 = getFieldByName("StatusPage_ID_Group")
// Get the value of selectList1
def selectList1Val = selectList1.getValue()
// If Select List 1 is set to <G4 - Systems value> "JIRA" then set seletList2 to option ""<component ID>.json"
if ("Other" in selectList1.value){
// Set the value to the ID of option "27mr8k9zyp8d.json" but must use value ID
selectList2.setFormValue("27mr8k9zyp8d")
// textBox1.setFormValue("27mr8k9zyp8d")
// Next Value
} else if ("Maestro" in selectList1.value)
selectList2.setFormValue("nxxj7vnbf0h5")
textBox1.setFormValue("nxxj7vnbf0h5")
// Next Value
} else if ("Ping Federate" in selectList1.value)
selectList2.setFormValue("qdqq66hyb7zg")
textBox1.setFormValue("qdqq66hyb7zg")
// Next Value
} else if ("VDI" in selectList1.value)
selectList2.setFormValue("gtztm9frh6lr")
textBox1.setFormValue("gtztm9frh6lr")
//Next Value
} else if ("A2Go" in selectList1.value)
selectList2.setFormValue("ml4f7y316gwq")
textBox1.setFormValue("ml4f7y316gwq")
//Next Value
} else if ("Allegiantair.com" in selectList1.value)
selectList2.setFormValue("41c919qx6ljm")
textBox1.setFormValue("41c919qx6ljm")
//Next Value
} else if ("G4Connect" in selectList1.value)
selectList2.setFormValue("f730dzmyygx9")
textBox1.setFormValue("f730dzmyygx9")
//Next Value
} else if ("JIRA" in selectList1.value)
selectList2.setFormValue("yrkk8q3n5cmq")
textBox1.setFormValue("yrkk8q3n5cmq")
//Next Value
} else if ("Crew Bidding Interface (CBI)" in selectList1.value)
selectList2.setFormValue("1pxk0h42n6ry")
textBox1.setFormValue("1pxk0h42n6ry")
//Next Value
} else if ("University" in selectList1.value)
selectList2.setFormValue("3vpr2l693bxl")
textBox1.setFormValue("3vpr2l693bxl")
//Next Value
} else if ("Alchemy" in selectList1.value)
selectList2.setFormValue("4xh0fm8vxxl6")
textBox1.setFormValue("4xh0fm8vxxl6")
//Next Value
} else if ("Teesnap" in selectList1.value)
selectList2.setFormValue("7kcfqs8f7zpc")
textBox1.setFormValue("7kcfqs8f7zpc")
//Next Value
} else if ("Tableau" in selectList1.value)
selectList2.setFormValue("9gg9shn8gncd")
textBox1.setFormValue("9gg9shn8gncd")
//Next Value
} else if ("airSMS (Q-Pulse)" in selectList1.value)
selectList2.setFormValue("jw879g23jchj")
textBox1.setFormValue("jw879g23jchj")
//Next Value
} else if ("G4Plus" in selectList1.value)
selectList2.setFormValue("mpkgzp3s2x7d")
textBox1.setFormValue("mpkgzp3s2x7d")
//Next Value
} else if ("PubWeb" in selectList1.value)
selectList2.setFormValue("n0z2qksf0jvd")
textBox1.setFormValue("n0z2qksf0jvd")
//Next Value
} else if ("SharePoint" in selectList1.value)
selectList2.setFormValue("qxll2nt9dtb5")
textBox1.setFormValue("qxll2nt9dtb5")
//Next Value
} else if ("Confluence" in selectList1.value)
selectList2.setFormValue("rtbw4hj8hlk1")
textBox1.setFormValue("rtbw4hj8hlk1")
//Next Value
} else if ("Wireless Network" in selectList1.value)
selectList2.setFormValue("v6v56ggmqxrm")
textBox1.setFormValue("v6v56ggmqxrm")
//Next Value
} else if ("Network Printer" in selectList1.value)
selectList2.setFormValue("yv70n7m7d3mp")
textBox1.setFormValue("yv70n7m7d3mp")
//Next Value
} else if ("Network Folder" in selectList1.value)
selectList2.setFormValue("yvyys1b9ldr9")
textBox1.setFormValue("yvyys1b9ldr9")
//Next Value
} else if ("AIS" in selectList1.value)
selectList2.setFormValue("zzjct3fsrrss")
textBox1.setFormValue("zzjct3fsrrss")
//All other selections
} else {
selectList2.setFormValue(null)
selectList2.setReadOnly(false)
I now can get all the values into the text field, but I need to convert them to a specific mapping. You can see the "C#" definitions in my code. Each C# is an actual value in the "selectList1" field and the mapping should go into the text field instead of the actual value within the multiselect field. I have updated my script to the following:
import com.atlassian.core.util.StringUtils
// Set List of Component IDs
def C1 = "27mr8k9zyp8d"
def C2 = "nxxj7vnbf0h5"
def C3 = "qdqq66hyb7zg"
def C4 = "gtztm9frh6lr"
def C5 = "ml4f7y316gwq"
def C6 = "41c919qx6ljm"
def C7 = "f730dzmyygx9"
def C8 = "yrkk8q3n5cmq"
def C9 = "1pxk0h42n6ry"
def C10 = "3vpr2l693bxl"
def C11 = "4xh0fm8vxxl6"
def C12 = "7kcfqs8f7zpc"
def C13 = "9gg9shn8gncd"
def C14 = "jw879g23jchj"
def C15 = "mpkgzp3s2x7d"
def C16 = "n0z2qksf0jvd"
def C17 = "qxll2nt9dtb5"
def C18 = "rtbw4hj8hlk1"
def C19 = "v6v56ggmqxrm"
def C20 = "yv70n7m7d3mp"
def C21 = "yvyys1b9ldr9"
def C22 = "zzjct3fsrrss"
if (selectList1 != null)
selectList2.setFormValue(selectList1.getValue())
selectList2.setReadOnly(true)
else
selectList2.setHidden(false)
