Hi @Cyberlogic Integration User
Do you mean for Jira Service Desk, as described here?
This one
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-comments/#api-rest-api-3-issue-issueidorkey-comment-post
But i cant see how to add internal comments.
I believe "internal" refers to JSD comments, and "visibility" is used for Jira Cloud comments. Visibility is described in the link you found and you can select the group or role who can see the comment.
I tried the json as provided and received an error, because it does not provide more information.
"visibility": { "identifier": "Administrators", "type": "role", "value": "Administrators" },
Is Administrators default for all admins working on issues?
Or is Administrators specific to some system?
Where can i see the groups or roles i can specify here?
This is the error i got.
When i remove that part, then it posts the comment, but not only internally.
Identifier is typically a number representing the text value, and value would be text. Please try removing one of them, as the error message states. If you keep identifier, you will need to determine the correct numeric value to use.
I was having this issue and this was the answer. Thank you.
