Adding the comment section is freezing, we are unable to scroll throught the older comments.
Sushmitha Sulanayakanahalli
August 28, 2025
Shalini Pradhan
August 28, 2025
Hello @Sushmitha Sulanayakanahalli ,
Good day! Welcome to Atlassian Community :)
Could you share more details on the issue you are encountering? Is your screen freezing while adding a comment? Or are you trying to add a large comment and while you are adding, you are unable to scroll down to see older comments?
August 28, 2025
yes
Shalini Pradhan
August 28, 2025
Thank you! Currently, when adding a comment in draft/edit mode covering the screen, it'll restrict the visibility of other comments in Jira tickets. And in some cases, the other comments won't be visible.
We have a feature request for the same to improve it
FR: JRACLOUD-95841
Thank you!
