Hello
I am trying to add a workflow to a project but the 'workflow' link is not in the project I am in.
Are you on Cloud? If so, it must be a next-gen project. Next-gen projects do not have the Workflows menu.
I am on cloud and i do think the project is next-gen.
Is this the issue?
What's the best solution? Create a new project?
In next gen projects you create workflows via boards (you add columns). If it is not enough. Then you would need to create a classic project.
