Addon create project from template and authorization concept problems
Jurica Petricevic
July 7, 2020
we are making some much needed changes onto authorization concept and we are wondering if its possible that as a Template made Project you can make a Single name workflow Scheme with a Project name at the front.
Backgroud: We wont to give some more playground to our Administrators/Projektowners but with it thay can when editing a current schema do a lot of harm to already in use Workflow Schemas/Projects.
2 accepted
Reshma Begum {Appfire}
July 7, 2020
Hi @Jurica Petricevic ,
We have a support request SUPPORT-3025 for the same issue in our portal. We will be providing further updates on this issue through the referred ticket.
Reshma
Jurica Petricevic
July 7, 2020
Thats pretty nice to hear. Your reactiontime its just awsome.
As i mantioned in support request i hope your solution can he transsmited in the same way onto Displaymask Scheme.
Jurica Petricevic
July 7, 2020
This is the Addon that we are using to make Templats
Delegated Project Creator for Jira by Wittified Atlassian Apps (an Appfire company)
Jurica Petricevic
July 15, 2020
Hi to you all @Atlassian Community,
there is some help i could need on this Problem. A Problem i have was rejacted from the DevTeam by Delegated Project Creator for Jira by Wittified Atlassian Apps (an Appfire company)
but if i can maybe find some more of you that can use this change maybe we can do it once again together.
This was the response and Issue was closed after that:
Kalyani Vunnava hat Sie in einem Vorgang erwähnt:
Thank you for being patient while we were reviewing your request.
Unfortunately, we are unable to include this request in our roadmap, at this time. We consider this an out-of-scope request for this app. Even if it were to be considered as a new area to explore and make it fit, we think it is a very specific case and may not be a welcoming change for other customers. However, we will revisit it at a time when more customers bring it to us with their business needs.
Please let us know if there is anything else we can help you with.
Thank you!
Issue is here to see:
https://wittified.atlassian.net/browse/PCFJ-628
