Addon for ability to see all project versions (+ dates) and features status
Ofira Daniel
Hi ,
Searching for add-on which can give me the ability to view all project versions (according to dates range) on timeline bar (or any other way where I can view version start & release dates) + list of version Epics.
Will be happy to get recomendations .
Ofira
Alexey Matveev
November 22, 2017
For exmaple, you could use Jira Portfolio. You can find more information here:
https://confluence.atlassian.com/jiraportfoliocloud/using-the-timeline-828785435.html
Ofira Daniel
Thanks , tried it already .
It is hard to work with tool which:
1) auto assign stories to owners in scrum team/s and I don`t have any ability to disable it
2) even if I plan my next X sprints , portfolio ignore and order the items in next sprints according to its algo and we failed to undertstand (it takes sometimes from BKL and some times from the sprints I defined and not according to my order)
3)  and more ...
If you have way to overcome above I will be happy to try it again.
Other suggestions ?
