Need a filter that shows me the following:
All issues in a specific project, that have no comments, created time 5 m ago.
I have this so far -
project = TEST AND issueFunction in hasComments(-1)
How do I state created time = created time plus 5 minutes?
Thanks!
created < -5m
Will give you "created more than five minutes ago"
Thanks Nic! That really helped.
My end goal of creating this filter is so that I can use it for hipchat integration. Basically, I want a specific issue type from a Jira software project to send a hipchat notification if a newly created issue has been sitting there more than 5 minutes without a comment added.
project = Request AND issuetype = Alert AND issueFunction in hasComments(-1) AND createdDate = -5m
I don't know how you're doing the hipchat integration, so I don't know if it will keep repeating the notification.
The query snippet I gave you will continue to report the issue whenever the query is run, so I suspect it will send it repeatedly (until there's a comment anyway).
If you want to fix it at a query level, then yes, you should time-box the query, but there is a problem with "= -5m" - the query would have to run exactly 5 minutes after creation to catch it.
Because I don't know how you're doing the integration, I can't really tell you how to fix it. If it's doing something like "run the query every 2 minutes", then you could say "createddate < -5m and createddate > -7m", but that might miss the odd one, so I'd go with createddate < -5m and createddate > -8m" and risk the occasional duplicate
