(1) If it's possible to include/view the real progress and the planned progress of the different "Projects, Phases or Epics" in the Advance Roadmap in the basic view?
(2) Also, if it's possible to export/download the data that is included in the Advanced Roadmap in the Basic View? To Microsoft excel for example?
The Basic View I am referring in both questions:
Thanks for your help and orientation!
Hi @Luz Guerrero and welcome to the community!
You'll just want to add the appropriate Progress field to your view - Progress (issue count) or Progress (story points). The option is dependent upon how your plan team is configured.
Under Share As, you can select csv
Hello @Mark Segall ! THANKS a lot for your prompt and very useful answers, I have done both successfully!
