Hi
We use Advanced Roadmap and we have a hierarchy set : Epic (1) Scope/assignment (2) - Deliverable (3).
I want to add a new issue type to level 2 and 3 due to creation of new hierarchy for other projects.
Will it change anything in existing linking?
If I want to use another hierarchy for different projects - can I set something like this?
Malgorzata
Hello @Małgorzata Adamska-Piotrowska
No, the hierarchy is applied globally. You can limit which issue types are available in a given project, but the hierarchy structure itself applies to all projects.
Hi Trudy. Thanks for the answer.
If I want to add a new issue type in the hierarchy - will I lose current links? I already have the hierarchy set, which I don't want to change. (My highest is Deliverable)
But if I add a new issue type for the highest hierarchy ( I will add Legend), will the current links to Deliverable be lost?
Honestly I have not worked that much with the AR issue hierarchy, so I don't really know the answer.
However, based on @Dave Mathijs 's answer on this post I believe you would not lose lower level links if you add another level to the top of the hierarchy.
