Already closed Issue but issue showed incomplete when to complete sprint
Ting
February 27, 2020
Already closed issue, but when I try to complete sprint, it showed that 0 issues completed, all other issue will be moved to next sprint, why?
Ashkan Malekly
February 28, 2020
Hii @Ting  and @Gergely Fehér
Columns are customizable and you can easily change them that you say move to the last column. I mean your open column can be the last column so if you move all of your issues in that status (open)( last column) sprint consider them as complete issues?no. But if you move all of your issues to open status but give them done resolution, sprint consider them as complete issues.
Ting
February 27, 2020
I got the solution, just move the 'Done' column to the last one.
Gergely Fehér
That is the solution: move all statuses what you deserve as done to the last column in your board.
Like Ta Minh Thuy likes this
Cojon2017
September 24, 2021
Thanks a lot, this solution worked for me! Actually, move the entire "Done" column to the right, to make it be the last one. Even if this is a bit stupid: not the position of the column should count, but its title (like To Do, Done, In progress etc). Thanks again!
Ashkan Malekly
February 27, 2020
Hii @Ting
Your issue must have resolution to sprint consider that as a complete issue.
