Already closed issue, but when I try to complete sprint, it showed that 0 issues completed, all other issue will be moved to next sprint, why?
Hii @Ting and @Gergely Fehér
Columns are customizable and you can easily change them that you say move to the last column. I mean your open column can be the last column so if you move all of your issues in that status (open)( last column) sprint consider them as complete issues?no. But if you move all of your issues to open status but give them done resolution, sprint consider them as complete issues.
I got the solution, just move the 'Done' column to the last one.
That is the solution: move all statuses what you deserve as done to the last column in your board.
Thanks a lot, this solution worked for me! Actually, move the entire "Done" column to the right, to make it be the last one. Even if this is a bit stupid: not the position of the column should count, but its title (like To Do, Done, In progress etc). Thanks again!
Hii @Ting
Your issue must have resolution to sprint consider that as a complete issue.
