Apply Issue search on a Jira Issues Macro
Moria April 27, 2021
Hi all,
I would like to reflect a long list of Jira issues on a Confluence page and then have the ability to further find a specific issue on that list by keyword search.
I have added the Jira Issues Macro and I would like to apply a search for a specific issue by keywords, but I only found search macros that search things on confluence and I did not find a search macro that can apply to that Jira issues Macro list I have added.
Does anyone have a suggestion for it?
Katerina Kovriga _Stiltsoft_
April 28, 2021
Hi @Moria ,
You'll need additional apps to filter the Jira Issues macro, for example, the Table Filter and Charts for Confluence app.
Wrap your Jira Issues macro into the Table Filter macro (or enable the Live Filtration) and you'll be able to filter your issues by keys, dates, priorities, statuses, etc. (similar to Excel).
Hope this helps your case.
Moria April 30, 2021
Hi @Katerina Kovriga _Stiltsoft_
That's actually a neat solution ;)
Thank you!
FREE
