Archived Issue does not have a Restore Button
KartikA November 13, 2020
I have an issue archived but the project is not archived. I do not see a restore button in the UI.
Please Help!
tokcum
November 13, 2020
Dear KartikA,
have you made sure that you also have the restore permission? Restore permission can be set as a global permission or at the project level.
Tobias
KartikA November 17, 2020
@tokcum
I have the restore permissions. Still unable to see the option. I am a Jira and system admin but still do not see that option. Thanks for your quick response.
Tasneem Bhyat September 13, 2021
Hi there
I am not sure if you found a solution, but you should check if the issue you are trying to restore is a subtask. If it is, then you will not see the 'Restore'.. Once you Restore the parent object, then the subtask will be restored.
Hope this helps
Thanking you
