Are Dashboards part of Jira or are they part of an add-on?
Jean Ann Harrison
I need to check if dashboards are included in Jira Cloud before I start using them because I have to be very wary of adding to our current service plan.  I have tried searching online but the results I'm getting back do not really state if dashboards are part of an add-on perhaps Jira Service Management or if dashboards are included.
Thank you for your patience.
3 votes
Kian Stack Mumo Systems
@Jean Ann Harrison
Dashboards are included out of the box! You can find more information about them here. That being said, there are many, many apps which you can purchase that will provide additional dashboard gadgets.
If there are particular dashboard gadgets you are looking for, feel free to check out some of the apps that may be useful to you. There are even some free ones you can explore!
Kian
Jean Ann Harrison
Thank you @Kian Stack Mumo Systems  for your response.  It's helpful.
Not a problem, glad I could be of some help!
Like Jean Ann Harrison likes this
