Hello Experts!
I need help with Issue creation in JIRA via CSV upload. I am facing below mentioned issues:
1) Assignee is not updated via CSV i have tried e-mail-id, User name
2) Reporter is not updated as per CSV, it is always current user(person uploading the CSV file)
There is one other custom field reviewer that is working good.( able to assign person via CSV)
I find User ID works well in Jira Cloud.
The User ID is the unique identifier each user's account has, and is ~40 characters long.
Three methods to locate this are:
^ You can utilise the User ID in the upload in place of name/email, and it'll successfully locate the right user for Reporter, Assignee or a custom user picker field!
Ste
Thanks Stephen for your help but it is still not working for me.
I used Issue search option to locate user ID then provided it for Assignee and Reviewer(Custom field)
Worked for Reviewer but Assignee is still blank(unassigned)
Name, E-mail id, user all three are working for reviewer but failing for assignee.
Don't Know if this is access related issue.
There's a few things it could be:
^ I'd check these out first!
Ste
Thanks, I did check 2,3,4. Will check 1st as well.
For now, I have updated Assignee after CSV upload via Bulk update option.
Thanks for all the help.
Note that the Reporter can be changed during CSV import only if that import is executed by a JIRA Admin by navigating to JIRA Settings > System > External System Import.
If you are using the Import Issues From CSV option that is available under the ... button on the Issue Search screen, you will not be able to set the Reporter through the CSV data, even if the operation is executed by a JIRA Admin.
Actually Reporter and Assignee can be set via either import option.
I used the user-level importer to test the above yesterday. It should work as long as you have the appropriate permissions (i.e Modify Reporter)
Ste
