×I am trying to build an issue collector for a specific project but the Assignee field is not visible to anonymous users and is required on this project. Problem: I cannot make Assignee optional because the setting is not available for that field in this project's configuration. "Allow unassigned issues" is ON in general settings. I have some projects where Assignee is optional and at least one where it is not. The setting is available in those other projects. Why would the setting be available in some projects but not in all projects?
The project that does not show the setting was created on an earlier version of JIRA (3.5, probably). The ones that show the optional setting were created either on 4.x or 5.1. Currently running on 5.1.
Confirmed that this simple work-around resolved our problem.
From Atlassian Support:
I have an update from the senior engineer. He wasn't abel to ascertain exactly what was causing the issue but he did discover a workaround. If you set the field to hide and then show this removes the 'required' aspect of the field. This seems to be a bizarre anomaly but this workaround should then allow you to add an issue collector. Let me know if this works or causes any issues. We've tested here and so far that looks viable.
Osman Afridi [Atlassian]
Atlassian Support - San Francisco
I confirm the same bug in latest 5.x, can we fix it? please.
*test*
Even I did not see Required option for Assignee field and then modified the workflows and added a Validator making assignee field mandatory.
Rgds,
Bhupesh
Did you manage to solve this? I've exactly the same issue, as I'm trying to use the issue collector. Stumped, and frustrated, too!
Due to other delays here at work, I only got the xml dump to Atlassian today. So, they are working on checking my system in depth now...
Now I have no configurations where Assignee has an Optional/Required setting. Sent Atlassian a service request. We will see what they can tell me.
Hi Randal,
As I know there was no ability to make assignee field required from the field configuration scheme. If you have "Allow Unassigned Issues" set to ON then the only way to make assigne field mandatory is to via third party plugin or some kind of customization (eg. JavaScript modifications)..
Do you have any plugins like JIRA Suite Utilities or using any other that are adding Conditions in the workflow that could make this field mandatory (for example when creating a ticket)? Are you aware about any changes to the JS code or maybe are you using some hidden custom fields that have a harcoded code?
BTW. Could you also check if you have a red star "*" next to the name of the field?
Best Regards,
Mirek
Hi Randall,
In your project where assignee is required, go to the project's field configuration and check if Assignee is set as a required field.
Read
Cheers
Bhushan
