Hi Team,
I want to Associate Test Plan to Test Execution using REST API.Is there any way to do it.
Using the following https://xxx.xxxx.xxx/rest/raven/1.0/import/execution/cucumber rest api to import Cucumber Test Results, what it happening new Test execution key is generating, without TestPlan associated. I want Test Plan to associate to Test Execution please provide the API for that.
Hi @Ashwin
You can use this endpoint to link a Test Plan to a Test Execution. Assuming you are using JIRA Data Center.
https://docs.getxray.app/display/XRAY/Test+Plans+-+REST
Regards
