Associating an issue type scheme with projects
Gerald Vassallo August 10, 2018
In relation to procedure below, i cannot find the project in the list, can you please help me out how I can make my project visible in the list.
  1. Go to the Issue Type Schemes tab (see above).
  2. Click the Associate link (in the Operations column) for the relevant Issue Type scheme.
  3. Using the multi-select Project box, choose the JIRA projects that you wish to apply your issue type scheme to.
  4. Select Associate and all selected projects will change from their current scheme to the selected scheme.
Fazila Ashraf
Hi @Gerald Vassallo
Not sure why it is not visible.. But you can do the same in a different way..
1. First , open the project and go to the project administration page.
2. Go to 'Issue types' tab
3. Go to Actions -> Use a different scheme
4. Select 'Issue type scheme' you want to associate with..
5. Click on OK
Let me know how that goes..
Dear Fazila
Thanks for your feedback, I have solved my issue. It was related to an update on Jira which affected our views. Thanks again
