×I'm trying to set up a rule to create a branch when an issue transitions to "In Progress", but it doesn't display my Github organization to connect to. I've already granted Atlassian Automation permission in Github. I've set up the Jira app in Github as well, which seems unrelated to this, but all of that is working. Any ideas why automation can't read my Github organizations?
Hi John,
Usually, this happens when Automation doesn't have access to the Github organization.
Can you please check if Atlassian automation is approved under OAuth application policy under GitHub organization settings?
User Settings > Applications > Authorise Oauth Applications > Atlassian Automation
Link: https://github.com/settings/applications#authorized
Additionally, you can check if Github is authorized from Jira side:
Hala
It all looks good. Revoked and tried to connect again. Same thing. No organizations to select.
In this case, can you please open a ticket with our support to further look into this?
Atlassian Support: https://support.atlassian.com/contact/#/
Hala
