Atlassian Fix for Cleaning XML backups not Working
Sam
I'm trying to follow the second solution provided in this KB article but whenever I run the line
java -jar atlassian-xml-cleaner-0.1.jar entities.xml > entities-clean.xml
I get the following output:
 -rbash: entities-clean.xml: restricted: cannot redirect output
 I've given everyone rwx permission on all files and I've even tried running this as the superuser, but I still get this output every time. Does anyone have any idea why this might be happening?
Nic Brough -Adaptavist-
September 16, 2020
This is down to your use of rbash for your shell - that restricts many of the functions that bash (and most other shells) do.
One of the things rbash prohibits is the use of redirection of output, the > in your command.
I think you'll need to run the command in a less restricted shell.
Sam
Thank you for clearing that up! I ended up switching to the root user and then running the command
It immediately worked. Thank you!
SERVER
VERSION
8.8.0
