I am trying to create a ticket in Project B when a ticket in Project A is created. I have tested the post function on a workflow step and it works when I ask it to create a ticket within the same project, but when I change the function to create the ticket in Project B instead of Project A, the post function does not execute. Is there a limitation or barrier I am not aware of? I am using the Jira Misc Workflow Extensions plugin to create the post function (JMWE).
There is no such limitation. However, it might be caused by a missing value for a required field, or by a permission issue. You need to check your logfile (atlassian-jira.log), or activate the "Make transitions fail when an error occurs in a JMWE post-function" option on the JMWE Configuration admin page to see the error on the transition screen.
That was it! Thanks David!
You can do this with Scriptrunner. Check out this post for the details:
