Automated Log Work for Jira
Rahma AJENGUI January 4, 2019
We have the "Automated Log Work for Jira" plugin and when we cannot generate the team report. We get the following error:
No data found for the given parameters
Worklog data error: Cannot read property 'worklog' of undefined
We tried with different worklogAuthor and it doesn't work.
Any advice please ?
Arun_Thundyill_Saseendran
January 6, 2019
From the quick look at the error, it seems more like a bug with the plugin. If I was you, the first step would be to increase the log level of the plugin to debug as described here and look at the logs to confirm that the error is because of the plugin.
A word of warning, JIRA spits out a lot of logs and it will be a bit noisy. However, if the logs are tuned right, then you would be able to catch the problem quite easily. Instead of looking at the existing logs, it would be good to tail the log and reproduce the error which is much easy.
It would be great if you could keep us posted on the further investigation as it will be beneficial for the community.
Arun
Rahma AJENGUI January 17, 2019
Thank you for your feedback, and sorry for the late reply.
I don't have access for the "Automated Log Work" log file as shown in this screenshot
(despite I have the admin credentials)
I only have the configuration option here :
Is there an other solution please ?
Please note that we use " A cloud Jira Service Desk Application 3.3.0-OD "
Many thanks
 Rahma
