Automatically add a comment to jira issue via Script Runner
Helen Ahlberg
how can I do this via script runner? Jira server v8.5.0
Martin Bayer _MoroSystems_ s_r_o__
Hi @Helen Ahlberg you need to use postfunction. Snippet with the example code is here: https://library.adaptavist.com/entity/add-comment-to-an-issue-in-a-post-function
Helen Ahlberg
I want to have a pre-defined value comment on every transaction.
Not a comment after the action is done but during the transaction
ex
My issue is moved from A to B and when pressing go_to_B I want a predefined value shown
ex: Enter the check you have done:
so that users can enter a comment after, And I want all of this to end up under Comment (not a custom field)
Is this possible?
Hi @Helen Ahlberg are you familiar with Behaviours (https://scriptrunner.adaptavist.com/6.20.0/jira/behaviours-overview.html)?
You can use this code in Behaviours script
def predefinedComment = "some comment"
getFieldById("comment").setFormValue(predefinedComment)
Helen Ahlberg
OK - but this will give me a pre-defined comment when just creating the issue?
We have behaviuor scripts that populate text in the Description field but this only happens with create issue.
My user want to have different pre-define commenttext when tranfering the issue in its workflow  - is this possible?
Question ->
is this the Jira 'field' comment?
Yes, behaviours works on transitions similary. You can use conditions in your source code (transition name, target status name...)
https://library.adaptavist.com/entity/limit-a-behaviour-to-a-specific-workflow-action
SERVER
