Automation - Apply Label to Task if not estimated
Jeremy Daugherty
A large number (50+) projects have been set up, but only a few of the issues in each project were estimated. I would like to apply a label at the Task/Story level to mark the issues without estimates. However, some Tasks/Stories have subtasks with estimates, if that is the case the label isn't needed.
Thoughts?
Edit: To clarify this is focused on time estimates not story point estimates.
Jeremy Daugherty
Here is what I did:
If: all match
  • issuetype = task
  • originalestimate IS EMPTY
  • Sub-tasks match originalestimate IS EMPTY
  • Then apply "Estimate-Needed" Label
Else-if: all match
  • issuetype = task
  • Sub-tasks not present
John Funk
Hi Jeremy,
Do you know the name of the field that stores the time estimates?
If so, you should be able to create a JQL query and then do a Bulk change to update the issues.
Jeremy Daugherty
Thanks John. I created an automation that runs weekly on selected projects.
John Funk
Were you able to get what you needed?
Like Jeremy Daugherty likes this
Jeremy Daugherty
Yes thank you for following up.
Like John Funk likes this
John Funk
Would you mind clicking on the Accept Answer button above so we can close this one out? Thanks!
