Hello
I need to copy value of single issue picker from triggering issue to child tickets. I could copy values of some fields from parent to child, but not issue picker. Can you please help me.
Here is what I have done so far:
Hi @AbrahamA
Testing this, this worked...
"fields": {
"customfield_10123":"{{triggerissue.High Profile Issue.key}}"
^ Just replace 10123 with High Profile Issue's custom field ID.
Ste
Hi Stephen
Thanks for the reply.
I have tried and it did not work.
Here is how it looks on trigger issue screen( I have made sure the field is visible on available on child issue view screen)
Hi Stephen
I did not see any errors on the screen.
The field 'High Profile Issue' does not have value for issue XYZ-538 and will not be displayed on the view issue page. Set value for that field so that it shows up.
Hi @AbrahamA
Is that the audit log error in the last comment?
Could you send a screenshot of your most recent rule, and an audit log entry from when you tried to activate the rule?
I tried this in our instance and it worked as required, so it should be possible to make it work in yours!
Hi Stephen
Thanks for your help, I got it to work.
For anyone facing similar issue, the fields should be in value changes. I had two fields with almost similar names and got mixed up,.
But since I am listening on description tickets from all projects are getting matched and appear in Audit log, wish project name could be matched first (is there a way)?
I am accepting answer as it solved my initial question.
In the audit log I do not see any rules failing for the tickets which belong to vrt. All are from different projects.
