I am trying to create an automtion rule that is sheduled to run at the start of each month.
The objective of the rule is create a new issue and two sub-tasks (in the same project).
When the rule is executed, an error is generated in the audit log.
Hi @NA ,
Can you please share a screenshot of your automation rule? Btw, did you check this other post? It can be a good reference to set the rule to trigger the creation of a task and subtasks at the start of the month:
