When I try to create an automation to send incidents to statuspage, the automation i created gives an error. Error may be about Statuspage API. How can I define API in statuspage?
There is an error photo following...
In send web request screen, is webhook url correct? If it is not correct, how can i fill in?
Hi @Berat Çolak ,
this is because you did not authenticate properly with the API : you should have a look at the documentation : https://developer.statuspage.io/#section/Authentication
Let me know if this helps,
--Alexis
