Automation: Find children of Epic, add their key to parent's comments
Fred
I have an epic with issues in it. I'd like an automation that will:
- check if this epic contains issues
- add a comment with those issue keys
From there, another automation will add 'relates to' links to those issues.
The epics will eventually be converted to tasks, and I'd like to keep a link to the children.
Variations on this failed for me.
I'm an admin, and have scriptrunner if it helps.
Thanks for any pointers!
Bill Sheboy
April 29, 2022
Hi @Fred
You note that you have an automation rule and that it failed to do what you wanted.  Would you please post images of the rule and the audit log details, showing where it did not work as expected?  That may help the community to offer suggestions.  Thanks!
Fred
Below is what remains. I scrapped the rest because it failed.Screen Shot 2022-04-29 at 4.28.21 PM.png
Bill Sheboy
April 29, 2022
Thanks, Fred.
That seems a bit different from what you described...perhaps that rule is assuming part of the problem has already been solved?
You noted two steps:
  1. for an Epic with child issues, gather the child issues' keys into a comment.  (I suspect you could also skip rule #2 and just add the links immediately.)
  2. later after the epic has been converted to a Task, use the comment to add links to the previously child issues
Your first rule could be:
  • trigger: manual
  • condition: issuetype is epic
  • action: lookup issues with JQL of "Epic Link" = {{triggerIssue.key}}  This assumes a company-managed project.  Substitute "parent" for "Epic Link" if this is a team-managed project
  • advanced compare condition: check if there are any children
    • first value: {{lookupIssues.size|0}}
    • condition: greater than
    • second value: 0
  • action: add comment, such as
"Here are the children to link later: {{#lookupIssues}}{{key}}{{^last}},{{/}}{{/}}
Fred
Bill, that works perfectly, thank you! Has the syntax for this solution changed? It's not working on our instance, and seems like it's failed for others.
It says 'The following issues did not match the condition:' which is the trigger issue.
Bill Sheboy
May 2, 2022
Hi, Fred.  I have not tried the rule in that post so I cannot confirm any changes.  Perhaps that regular expression is sometimes not matching for other reasons, such as...
In answering another question about extracting links from the description, I found they are stored as "smart links" in the markup.  Perhaps the same is true for the comments markup.  You can confirm this by writing the comment body to the audit log.
https://community.atlassian.com/t5/Jira-questions/Create-automatic-linked-issues-when-writing-an-ticket-number-in/qaq-p/2014794
One other work-around is to store the keys in the comment with the first rule such that they cannot be turned into links, such as adding spacing around the hyphen in the key.
Like Quentin Schneider likes this
