I have a custom field for Percent Complete. This is a single picker field with a few simple numerical values to choose from.
The team wants the Percent Complete field to be automatically updated when the status of the issue is changed. Here are the business rules:
Can you help me identify what's wrong with this Automation? It doesn't seem to be working. Here's what I currently have running (which doesn't seem to do anything at all).
Hi @sgover
As written, your rule is stopping as soon as the first condition is not met.
For your scenario, there are two solutions:
Lookup Table probably the better way to go. Thanks @Bill Sheboy
When you click on the show more button on the audit log does it have anything extra?
What status is currently giving you issues? Is it on every transition?
I've tried several combinations with various issue types, but it doesn't seem to work at all. I'm getting the following result in the audit log.
What if you tried using the IF or ELSE condition instead of using issue fields condition?
