×Acording with the documentation, Automation JQL condition suport smart values.
How do i set de following condition?:
Find issues that have the same custom field date as trigger issue.
Your image appears to show too many curly-brackets around the value. Please try just two around each side:
{{triggerIssue.customfield_10043}}
Of note: what is the type of your field? If it has a time you may need to strip off the time part for the comparison by changing the format:
{{triggerIssue.customfield_10043.jqlDate}}
Thank you @Bill Sheboy for answer,
The custom field is a Date Picker type.
I´ve tried with both format that you mentioned:
Thanks, Sofia. What that error tells me one of three things is happening:
Let's try this: immediately after your trigger, add two things:
Checking {{issue.key}} for custom field = {{triggerIssue.customfield_10043}}
a) If the rule works after adding the re-fetch, the cause was #1
b) If the audit log does not show your date, it is either #2 or #3
Thank you very much @Bill Sheboy !!!
You were right, the rule was running too quickly, so the field was empty.
I modify de trigger to give it time, and got the result expected.
Thank you!
Awesome! I am glad that helped.
Hello @[deleted]
Your thorough reply here helped me in a completely different use case.
In my use case I am receiving data from an API interface and the problem is that my automation is executed based on the transition and later there are a few branches, where one of them is selected based on some value in a custom field.
The problem with the interface was, that it worked in two steps - first the re-open transition and then the update of fields. As a result of this design, the automation got initiated while triggered by a transition, however the data needed for the automation could not be yet updated.
With the 're-fetch issue data' action (which I seldom use), I noticed that this can put the automation execution on-hold for the whole 5 seconds! This is more than enough for the interfce to update the issue over API and when it is finished, my automation will jump in and continue. Wonderful :)
Screen 1
Screen 2
I am glad to learn that helped you. And...it appears you are using Server/Data Center version, as the Re-fetch action does not have the "delay rule" option for Cloud.
Instead using Re-fetch for Cloud slows the rule for about 1 second (or more). I recall there are suggestions in the backlog to add "wait until the prior step finishes" or "delay X seconds" actions.
Hi @Bill Sheboy I hope you can help me.
I have a case similar to Sofia's but in "if : Issue match JQL" I want to search for issues that have the same Account as the trigger issue. Apparently the smart value must contain {{issue.TempoAccountField.value}} but I can't write a correct condition.
Estelle
For older threads like this, I recommend creating a new question and linking back to the older one. Otherwise only the people following it will see your question to offer suggestions. Thanks!
Would you please post an image of your complete automation rule, the details of the condition with your JQL, and the audit log details showing the rule execution? Those will provide context for your question. Also, what version of Jira are you using: Cloud, Server, or Data Center?
Until we see those...
Smart values are name, spacing, and case-sensitive. And often the smart value does not match the displayed field name on the issue views. The how-to article below helps to identify the correct smart value (and custom field id) for any supported fields for automation rules. The essential steps are:
https://<yourinstanceurl>/rest/api/2/issue/<issuekey>?expand=names
https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
