User case:
The automation is triggered when an Issue type "Initiative" is made
It creates an Epic
Under the field "Epic Name", I want to copy text from a field in "Initiative", let's say field name "Panel ID", and add a new text after it, i.e.
In Initiative, field "Panel ID" has "1234" as a text.
In the Epic, Epic Name will copy the Panel ID above and add "Planning" text after it: 1234 Planning
Hi again @Richard Canlas
Sure Got it This can be achieved with the previous rule itself. Give me some time!!
For other Community members, here's the context
So the automation update you need to do is here
Update the epic name to {{issue.Panel ID}} Planning as shown below
Let me know if this worked for you!!
Pramodh
