Automation - Payload for custom variable is too large
Cristina Carrillo
 I am running into this issue when attempting to send one email to each assignee containing all their issues not updated in the past 4 days. I originally was running the single email for each issue but it quickly filled my inbox. Is there another way to send one email to each assignee for all issues not updated past 4 days?Screenshot 2023-05-19 at 10.31.49 AM.png
Alex Koxaras -Relational-
Hi @Cristina Carrillo
Why do you need the 2nd lookup inside the branch?
Cristina Carrillo
Took the automation from this recommendation, although the link one is for tickets due Automation rule to send single email for all issues per assignee due next week
But yours is different that the one in the example. You didn't include the {{distinctAssignee}} on your second lookup, thus you are not narrowing down your results and your payload is big (most likely this could be the cause).
Cristina Carrillo
Guess I missed that, only issue now is I am unable to validate the query like before and cannot run the rule to ensure it is working as intendedScreenshot 2023-05-19 at 12.28.45 PM.png
You can't validate a JQL when there are smart values present. Just go for it!
Cristina Carrillo
Screenshot 2023-05-19 at 1.23.00 PM.pngSame issue
krunoslav.majer October 26, 2023
Heyhey,
Any luck with this issue? I am facing the same and I am just processing roughly 40 issues with 4 fields. It worked and then it just stopped working and this issue appeared.
Olive, Lamarr
November 30, 2023
I am facing the same Payload issue.  Do we have a viable solution?
Shane Sterling
January 15, 2024
Same problem
Eric Coidan
April 1, 2024
Same Problem here as well. Only 47 issues and getting the "Payload for custom variable is too large, try reducing the amount of data stored in your custom smart variable"
