After a bug is closed there are often a number of tickets that need to be worked on to ensure that this does not happen again and/or to clean-up any related issues caused by the bug.
I would like to build an automation rule (or rules) that adds a label to any ticket (for the purposes below I will use "task") that is linked to a Bug so that we are able to identify what % of them get completed throughout the year.
I've been able to build the following rule:
What I am having trouble with is figuring out the condition for:
Key things to consider:
Some workarounds I've put in place for now:
Any ideas?
Hi @Mark Segall i am trying to build the rule such that it can be any type of link. That way user error is lower.
That said, one of the workarounds I was able to identify was: I can make the rule work if I build the rule based off the link type and not build a condition around issue type.
However, I fear (and the feedback I received from stakeholders) was that users may not select the correct link type and therefore our data would not be as accurate as we hope.
Got it. So is there a reason why you have the bug condition? Does a bug get a different label than a task? If so, you could try this:
key = {{destinationIssue}} AND issueType = Bug
key = {{destinationIssue}} AND issueType != Bug
The reason for the condition is because without it if we link any task to any other task then it will add a label which we don't want. We only want the label added to tasks that are linked to our Bugs.
Just to take a step back, this is what I am trying to do:
At our organization, the workflow for bugs is:
Prod bug occurs > we quickly resolve it > we perform a retro > during retro create tasks > we link the tasks to the bug > (this is what I am trying to figure out) linked tasks automatically get a tag/label or something else so we can track the tasks and build metrics.
Got it... So you could potentially tweak it like this:
Hi @Mark Segall
The test I am performing for the below is: I am in the bug ticket and link that bug ticket to a task.
When I tried the above:
I got the following "no actions performed message":
Which spawned the idea to try:
But I got the following "no actions performed message":
From what I can tell by looking at the second rule, it seems like even though the JQL condition is referencing the "{{destinationIssue}}" (Bug) it is still running the query against the "{{issue}}" (Task).
Sorry - Error on my part. Let's replace triggerIssue with issue in those two conditions (I've updated my last post):
{{issue.issueType.name}}
Hi Mark, the proposal did not work.
This is what I tried:
This is the no actions performed message:
I've been playing around with the lookup function to see if that is a possible solution. But I haven't been able to nail it down. Thoughts on using that function?
Let me take a step back on this. I don't think Lookup Issues is necessary. What if we just do this:
Thanks again for the response @Mark Segall ! Upon attempting the above, I received the following No Actions Performed message:
Are both of these issues on the same project? I ask because if they're on different projects, you'll need to update the project scope (rule details). This would need to be done by a Jira Admin under Settings >> Global Automation.
And for the IF condition did you make sure to change it so that it acted as an OR instead of AND?
Sorry to ask again, but can you confirm whether the two issues are in the same project or not?
Sorry for the confusion. Yes, they are both in the same project.
Ok - No idea why it has to be set up this way, but I got it to work when I did this:
For some reason, when you use a JQL, it automatically adds "AND Key != {{destinationIssue}}" which makes no sense to me. So, I went with the above and it worked for me no matter how I set up the links.
@Mark Segall You did it!! This seems to be working beautifully. Thank you so much!
The below are the tests I performed to ensure it was working properly.
Test 1: Successful
Test 2: Successful
Test 3: Successful
Test 4: Successful
Is there a way to do this where the destination is in a different project?
Hi @Renee Niewald - Yes. You need to make sure the rule scope is set for multiple projects or global. This is done from System >> Global Automation.
I think my use case may be different but maybe you can still help. When we have Incidents we want to track the follow up work. There are 2 ways we know there will be follow up work: 1)followUp label is added to the Incident in project "Incident Response" OR 2) An issue is linked to the Incident in project "Incident Response" but it may be in a different project space"
In each case, we want to ensure the followUp label is added to the Incident and the linked issues.
Since this is slightly different and so that this can be easily findable later, can you please create a new question and @mention me in it?
Thanks!
@Mark Segall if the rule is Global, which is how I set up my rule, the solution should still work. If I have a bug in project A and create a standard issue (for simplicity call it a task) in project B, the rule it will still add the label to the task.
Feel free to @mention me in the new question if you'd like to collaborate.
