Automation advanced compare check not working
Musa Cuvarov April 14, 2022
I have set the automatic creation of tasks and their sub-tasks at a certain time of day, it works fine.
Now I need to create another subtask for this task only if today is Monday, for that, I used advanced compare condition
 {{issue.parent.created.format("E")}}
exactly matches regular expression
(Mon)
then create a sub-task, but it's not working.
Coud you please advise solution?
Thank you!
Tessa Tuteleers
Hi @Musa Cuvarov ,
so if you create a task on monday, a subtask needs to be created?
As your condition is on the task itself, you don't need to refer to the parent.
So the trigger would be "issue created"
with an advanced compare condition of
{{issue.created.format("E")}}
(Mon)
And then the create subtask action.
- Tessa
Hi @Tessa Tuteleers
I have already tested the way you suggest, but it isn't working too...
For better understanding please see the screen
Thanks for responding.
Regards
Tessa Tuteleers
Hi @Musa Cuvarov ,
I see in your screenshot you still use the parent smart value.
I made a quick test and for me it works like this:
(of course I tested with Thu and not Mon since it won't work otherwise today :p )
Also, for testing purposes, please add a log action to your automation with the smart value in it, to see what it actually gives back.
Amazing, It's works now👍
Great thanks!
Regards
