Automation and Confluence triggers
Jovânio Sousa Morais Junior November 15, 2024
Is there another possible action other than "Create Confluence Page"? How do I take action in my automation? For example, commenting on an existing document in confluence? Analyzing Jira's automations I only found the option to create page, would that be right?
Uladzislau Samuseu
Hi @Jovânio Sousa Morais Junior
You could use "Send web request" automation action to send request to Confluence API to comment specific Confluence page.
Check this API docs:
https://developer.atlassian.com/cloud/confluence/rest/v2/api-group-comment/#api-group-comment
Nikola Perisic
Hello @Jovânio Sousa Morais Junior
What is your use case that you are trying to accomplish with the automation?
Automation is possible for the scenario: When Project information was changed or comments were added, this information is taken to Confluence
Like Humashankar VJ likes this
From what I saw in the documentation, it is only possible to create a new document using automation, wouldn't it be possible to update an existing document? perhaps a comment on an issue will be replicated in an existing doc.
